Remote API - eid vs sid question
Тема: Remote API - eid vs sid question
Hello there!
I have a simple question: when I use the login function of the Remote API I'm getting a string in the returned eid field. According to the documentation, that's the session id and should be an integer.
However, I get a string back; and when I try to use that value with the other functions that use the sid parameter, I'm getting errors.
Naturally, I also tried to convert the eid value to an integer, so that I can pass it as the sid.
No success so far.
Can you please help me to sort this out?
Thanks in advance!
(19/10/2012 12:26:35 отредактировано zorrow)
Re: Remote API - eid vs sid question
BTW, this is what I'm doing:
http://hosting.online.stavtrack.kz/wialon/ajax.html?svc=core/login&params={"user":"myuser","password":"mypassword"}
From this call, I'm getting a result that looks like this:
{"eid":"94f16b429929efe426999b35a5667170".... etc. }
How can I use that returned eid value as the sid for a call to, let's say, logout?
Field eid has string type. We will correct this mistake in the documentation.
kopa пишет:
Ok, so... how do I use it as the session ID? Or in other words, how do I get the value to pass to the "sid" parameter then?
Thanks again!
zorrow
have you tried to pass a string-type "sid" (as "eid" is)?
Developer
I did try something like this -and it doesn't work:
http://hosting.online.stavtrack.kz/wialon/ajax.html?svc=core/logout&sid="94f16b429929efe426999b35a5667170"
I haven't tried something like this -I will tonight:
http://hosting.online.stavtrack.kz/wialon/ajax.html?svc=core/logout&params={"sid":"94f16b429929efe426999b35a5667170"}
However, I strongly prefer avoiding the trial-and-error approach with third-party APIs. I'd better rely on documentation and support.
In any case, it seems like some people around are actually using the Remore API. So, can you guys please provide some examples to, let's say, log in, get the list of units, get the list of POIs and then log out?
Thanks a zillion in advance!
PS: Please don't refer me to the documentation for the examples. I already tried those and we have already confirmed the "eid" field is wrongly documented.
Try to use:
You don't need to use quotes around HTTP parameter "sid".
kopa пишет:
Try to use:
Ok, this does work. Huge thanks! Now I can move on with all what I want to do. If there's more blocking issues, I'll certainly let you know. wink
Thanks again!
