User Timezone update with Daylight saving time
(17/06/2021 10:32:58 отредактировано arsalanqayum332)
Тема: User Timezone update with Daylight saving time
Hi there,
We are trying to update user timezone but could not figure our how does AND (&) and OR  (|) bit operator works when calculating with daylight saving time.
Example URL
https://sdk.online.stavtrack.kz/wiki/en/sidebar/ … me/example
There are hexadecimal values given: -3600 and 0xf000ffff
-3600 & 0xf000ffff
-268373520
After converting hexadecimal values to binary and performing & bit operator we are getting different results.
Can you please give hints how this calculation is actually working.
Best Regards
Re: User Timezone update with Daylight saving time
Hi Arsalan,
First it needs to perform negative value (-3600) to binary as signed value (32 bit), using two’s complement method, where we get invert result : 0 instead 1, 1 instead 0 , plus 1
After we get correct binary value, we can apply mask 0xf000ffff and operation & (and).
We get some binary value which is decimal signed value (negative)
So for this binary value we apply DST mask with operation & (OR) , if there is not DST - the mask = 0x8000000
Final binary value will be represented some decimal negative values, for example tz=-134155792
Here is converter https://www.exploringbinary.com/twos-co … converter/ can help to see how values are performed
(17/06/2021 10:33:11 отредактировано arsalanqayum332)
Hi Diana,
Thank you for your response.
I understand a majority of what you explained, however I’m stuck on where I can find out what daylight saving time was selected when user saves Time Zone.
Here is example from beginning to end.
User selected timezone, International Date Line West: -43200
-43200 (32 bit) binary using two’s complement method = 11111111111111110101011101000000
We need to perform the operation with mask 0xf000ffff, which has binary equals to = 11110000000000001111111111111111
11111111111111110101011101000000 & 11110000000000001111111111111111 = -1111111111111010100011000000
-1111111111111010100011000000 = -268413120
And we are going to select daylight time saving United States, Canada: from second Sunday in March to first Sunday in November with mask value equals to 0x0A010000
-268413120 (32 bit) binary using two’s complement method equals to = 11110000000000000101011101000000
Daylight time saving mask 0x0A010000 binary is equals to =  1010000000010000000000000000
11110000000000000101011101000000 | 1010000000010000000000000000 = -101111111101010100011000000
-101111111101010100011000000 = -100575424
We are on track so far!
Now to reverse the saved settings.
-100575424  (32 bit) binary using two’s complement method = 11111010000000010101011101000000
We need to perform an operation with mask 0xffff, which has binary equals to = 1111111111111111
11111010000000010101011101000000 & 1111111111111111 = 101011101000000
101011101000000 = 22336
To find out what timezone user selected, we need to perform OR operation with mask 0xffff0000
22336 (32 bit) binary using two’s complement method equals to = 00000000000000000101011101000000
We need to perform | (OR) operation with mask 0xffff0000, which has binary equals to = 11111111111111110000000000000000
00000000000000000101011101000000  | 11111111111111110000000000000000 = -1010100011000000
-1010100011000000 = -43200
We successfully reversed timezone value -43200, International Date Line Wes.
But I cannot not understand how to reverse daylight time saving  United States, Canada: from second Sunday in March to first Sunday in November value during the process
Your hints and direction would be highly appreciated.
Thank you,
arsalanqayum332 пишет:
But I could not understand how to reverse daylight time saving  United States, Canada: from second Sunday in March to first Sunday in November value during the process
Thank you,
Arsalan .
Hi Arlasan,
When you apply Daylight time saving mask with value 0x0A010000, you just need to apply value = 0x08000000  which means there is not any DST settings.
