Тема: conexion api
Hi good day
I would like to know what the heading of the header is like to be able to connect with the nimbus api.
. {"error": 2, "details": "Url does not exist or your pass invalid params."}
I appreciate your help.
Hi good day
Hi carlos
Could you please provide more details on request you are trying to perform?
hello neil
I am trying to consume the nimbus api but I do not understand how to assemble the header to make the connection
Hello, carlos
curl -X GET https://nimbus.online.stavtrack.kz/api/depots -H "Authorization: Token your-token"
If this will not help you, please provide more information - how do you make request, which tools do you use, which programming language and which url.
The url that I am using is the following
https://nimbus.online.stavtrack.kz/api/depots -H "Authorization: Token ХХХ"
Dear carlos!
It is difficult to help you without any details on the matter. Please, specify as our team have requested earlier:
- how you make the request
- what kind of tools you use
- which programming language
We understand that you are trying to work with NimBus API, but we need more information.
If you describe what you are doing and what result you expect in details, it'll be possible to give you more specific instructions.
Also you can write a letter with details to support@gurtam.com
