Тема: Uploading image for POI
Hi everyone
We want to add image for POI using SDK. We are developing an android application. we use below code and server response error 4
FileInputStream fileInputStream = new FileInputStream(sourceFile);
URL url = new URL(urlString);
// Open a HTTP connection to the URL
conn = (HttpURLConnection) url.openConnection();
conn.setDoInput(true); // Allow Inputs
conn.setDoOutput(true); // Allow Outputs
conn.setUseCaches(false); // Don't use a Cached Copy
conn.setRequestMethod("POST");
conn.setRequestProperty("Connection", "Keep-Alive");
conn.setRequestProperty("Host", "hst-api.online.stavtrack.kz");
conn.setRequestProperty("Cache-Control", "no-cache");
conn.setRequestProperty("Accept", "text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8");
conn.setRequestProperty("Accept-Charset", "windows-1251,utf-8;q=0.7,*;q=0.3");
conn.setRequestProperty("Accept-Encoding", "gzip,deflate,sdch");
conn.setRequestProperty("Accept-Language", "ru,en-US;q=0.8,en;q=0.6");
dos = new DataOutputStream(conn.getOutputStream());
dos.writeBytes(twoHyphens + boundary + lineEnd);
dos.writeBytes("Content-Disposition: form-data; name=\"params\"\n" +
"\n" +lineEnd+lineEnd+
"{\"itemId\":"+id+",\"poiId\":"+poiid+",\"eventHash\":\"jUploadForm1372768029714\"}"
+ "\"" + lineEnd);
dos.writeBytes("Content-Disposition: form-data; name=\"eventHash\""+lineEnd+lineEnd+"jUploadForm1372768029714");
dos.writeBytes("Content-Disposition: form-data; name=\"poi_dlg_props_upload_image\"; filename=\"zZeVUgLEJXE.jpg\"");
dos.writeBytes(lineEnd);
dos.writeBytes("Content-Type: image/jpeg"+lineEnd+lineEnd);
// create a buffer of maximum size
bytesAvailable = fileInputStream.available();
bufferSize = Math.min(bytesAvailable, maxBufferSize);
buffer = new byte[bufferSize];
// read file and write it into form...
bytesRead = fileInputStream.read(buffer, 0, bufferSize);
while (bytesRead > 0) {
dos.write(buffer, 0, bufferSize);
// send multipart form data necesssary after file data...
dos.writeBytes(twoHyphens + boundary + twoHyphens + lineEnd);
// Responses from the server (code and message)
serverResponseCode = conn.getResponseCode();
String serverResponseMessage = conn.getResponseMessage();
Any one can help us and explain what's wrong with our code ))) ?
Consider that we create POI in our app and then in this step we get error 4. some inputs in the codes comes from previous step of creating POI.
Thank you all!
