Water and Electricity Metering (AMR)
Тема: Water and Electricity Metering (AMR)
Hi All,
Completely off the topic here - apologies for this.   Administrator can move the topic to the correct location.
We need a solution that can give us a Wailon / Gurtam similar product for monitoring Water and electricity.
The system must be able to read remotely from water and electricity meters in the field e.g. GPRS.
System must also be able to handle minimum of 100 000 meters in different areas.
A similar system like Wailon / Gurtam must be able to handle different hardware manufacturers but all write to one software platform.
Let me know if you can assist.
Many thanks - Ruaan
P.s. I also spoke to Anisa, that gave the OK to post on the forms.
Re: Water and Electricity Metering (AMR)
Ruaan,
Did you get any answers on the topic you posted?
Phoenix Solusi
Mobile Visible Secure
Hi Ruaan,
where is the problem?
Wialon can do that out of the box.
you just need to have the coresponding hardware which has a specific protocoll. Protocoll will be implemented by Gurtam HW team and thats it.
We use Wialon for many purposes just as an translator between different HW and for saving and showing of data. The guys developed it in a so universal way that you can use it really for everything.
Wolf.
(14/11/2014 12:40:54 отредактировано pomi123)
Sometimes there is problem with the fuel sensor due to which it send constant fuel level to the wialon for very long period of time so is there any possibility to make such type of notification from which we will get this constant fuel level alert.
You can easily check CCD-410 latest exam questions with help of latest  Avaya latest resource University of Advancing Technology certification dumps certification Massachusetts Institute of Technology (MIT) paced test engine to help you pass Nova Southeastern University
Sensolator enables monitoring values of counters and sensors http://apps.online.stavtrack.kz/docs/en/sensolator.html
Labs Expert
wwbusch aka Buwo пишет:
Hi Ruaan,
Wolf.
currently not possible as all parsers coming in to wialon servers check for GPS valid status flags, if device is indoors for example there is no data to show in real time.  if device has GPS receiver and is outdoor is another story
i asked to wialon team to support this feature, as the market of M2M devices and ioT (internet of things) is growing so fast,
on many places of the world there are some companies offering this kind of platforms, for example
etherios
jasper
kore
carriots
axeda
and the list goes on...
Spread the AVL- World
Hi Small_Gprs.
not correct,
gurtam made for us for example at vt310 protocoll the additional function to register messages even with invalid gps, than it uses the server time. (we use it for inhouse measurement of waste containers...)
so as always: just ask...
Wolf
Thank you by your answer, i'll add this info to our ticket unresolved until today !
