No data from sensors¿
Тема: No data from sensors¿
i am making this call to get values from sensors but all sensor are empty, for example Km CAN :
http://prntscr.com/qlakkk
core/search_item&params -->
why¿'
            "4": {
                "id": 4,
                "n": "Km CAN",
                "t": "mileage",
                "d": "",
                "m": "km",
                "p": "can_mileage",
                "f": 0,
                "c": "{\"act\":1,\"appear_in_popup\":true,\"ci\":{},\"cm\":0,\"lower_bound\":0.5,\"mu\":0,\"pos\":7,\"show_time\":false,\"timeout\":0,\"uct\":0}",
                "vt": 1,
                "vs": 0,
                "tbl": [
                        "x": 1,
                        "a": 0.005,
                        "b": 0
Locating things
Re: No data from sensors¿
Hello!
the response returns information about sensor settings - name, parameter, calculation table and etc.
To get last sensor values you can execute request unit/calc_last_message , or to get counters value set up flag Counters to in request search item
aaaaaaaay aaaaaaaaaaaaay!!!! Dianaaaaaaaaaaaaaaaaaaaaaaaaaaaay
thanksaaaaaaaaaaaaaaaaaaaaaaay
Locating things
and how do I know each sensor ID? do I must check it with the client s front end...or is there any call that will return me the
Senso XX is 1
Senxor XX2 is 2
Sensor XXN is n
? maybe?
thanksay
Locating things
where is this data?
http://prntscr.com/qlsay2
I want the tacho info driver
thanks
Locating things
Good day,
in request  unit/calc_last_message  if not specified 'sensors' parameter or empty - return values of all sensors
But this request can return only number values, not text , like in your case value for Conductor.
To get all possible types values it's through request events/check_updates  with "detalization":3. Before it needs to load required units to session - https://sdk.online.stavtrack.kz/wiki/en/sidebar/ … date_units
the other way just get info from last message as raw parameters - search item with flag Last message and position
ok, but no I/O info
i want this: http://prntscr.com/qlwdb4 also..
cane be? or to know Engine state (connected to DIN) I must check in sensors call?
thanks
Locating things
locationGPS пишет:
ok, but no I/O info
thanks
Hello!
I/O parameters are raw data, so they can be get only from messages params
as for Engine state - ignition sensor which created for unit - it's possible via request  events/check_updates the same as described above
ok, i ll get engine state from sensors, question...Client asks "ok, engine is OFF", where do i get the info regarding how long was stopped?
from stops report? or is there any other way? (I found in tacho info there are those info BUt of course, not all trucks have tacho installed..
thanks
Locating things
locationGPS пишет:
thanks
as request events/check_updates can return time when sensor is get value (0 or 1) you can calculate duration on your side
for  example
ignition: {2: {from: {t: 1578665386, y: 53.9058570862, x: 27.4567871094},…}}
f: 2
hours: 5638064
m: 1578995183
state: 0
switches: 43
to: {t: 1578665873, y: 53.9058532715, x: 27.4573307037}
type: 1
value: 0
start to calculate from last sensor time - to: {t: 1578665873} , in next response  get the same state  - calculate duration, ....etc  then in some response get new value state:1, so process calculation to Off sensor has broken, start to calculate On duration and etc.
I think it will work out... we test and complain.
tjhamnks
Locating things
