Тема: Create Unit
i try to use the API remote to create item :
but i get error 4 as response (check the joined file)
Hello!
there is not hwTypeId as 18721183
You can get all available hw types with their id by request core/get_hw_types
Hola,
Estoy tratando de crear una unidad con los siguientes parametros :
y me esta dando
"error": 6
obtuve los datos del usuario :
"host": "186.67.179.2",
"eid": "09238654931419b4aaccebd484dba628",
"gis_sid": "8d36378d",
"au": "kaufmann_demo",
"tm": 1582559676,
"wsdk_version": "1.281",
"base_url": "https://hst-api.online.stavtrack.kz",
"hw_gw_ip": "193.193.165.165",
"hw_gw_dns": "nl.gpsgsm.org",
"user": {
"nm": "kaufmann_demo",
"cls": 1,
"id": 20676297,
Que esta fallando ?..
Muchas gracias
Good day!
The error 6 means that user-creator cannot create items due to billing rights, or access rights (token access, user's access).
For your user "kaufmann_demo" billing on account / billing plan is ok, it also seems ok with user's access rights.
So please check the token access (parameter 'access type' ) - you need to login with token which have access flag no more than 0x200(512)
For example, you can use the following URL to get token https://hosting.online.stavtrack.kz/login.html?access_type=768 (or full access: access_type=-1)
Please note we provide support on English here.
