Mileage counter differs the real odometer
Тема: Mileage counter differs the real odometer
We have connected one client all 400 units odometer from on board computer the real the correct value directly from odometer and the problem is, it differs after sometime with counter on fleetrun. That is because service distance counter is independent and it works as simple counter like this https://docs.online.stavtrack.kz/en/local/cms/units/counters.
It would be very logical to use not counter but direct value from on board computer odometer if there is one.
Re: Mileage counter differs the real odometer
Dear ernestas ,
First, contact our support team with a couple of examples. As common, problems with mileage counter are caused by incorrect incoming data. Support team will help you to detect sources of problems and may give some hints on how to set the sensor.
But you are not the first who rise up such theme, so we will pay attention and try to do something more clear with this function.
Tatsiana Shmihelskaya
Business Analyst, Gurtam
